If you turn superfetch off, no wonder your vista install seems slow...
Oh it seems quicker with it off... that would be because I am allowed to use my hard drive again.
I have a Q6600 also. I expected Vista to perform subjectively quicker than my old P4 did, but was left very underwhelmed.
Me neither. It's so unbelievably dated. But then it is getting on for being, fundamentally at least, a decade old.I can't stand using XP anymore.
Don't remember the time I explained Vista's I/O scheduling and prioritisation then?
PS: You NEED Superfetch if you want Vista to be fast.
We may as well stop because this really is a case of "facts versus subjective and slightly jilted opinion".
For it to keep it in memory does it mean you have to keep the PC on all the time or in standby?
Yep - Vista cannot magically load anything quicker than XP does because the bottom line is, at some stage the hard drive needs to spin and be read, and that is no quicker on Vista obviously. So it is smoke and mirrors really.
Obviously, if you go to a Vista machine which has been on for a while and has all of your most used apps sitting in RAM, versus an XP machine which doesn't, the Vista machine will load those apps in a flash. But supposing you turn both machines on from a cold start and just want to load Firefox for example, it won't be one iota quicker in Vista than XP because they are both loading it off the hard drive.
But in XP as well, it doesn't purge its RAM the minute you quit a program anyway. Chances are if you run a game, quit it then go back to it later, it will still be in the RAM and will load in a flash too. Now I have 2 gigs in XP I find that regularly.
I believe Vista was designed with long up time in mind, and sleep mode being used instead of shut down (hence it's the default power button on the start menu).
Also one has to wonder what it does to hard drive longevity versus XP, for it to thrash the drive so much - often needlessly because you won't always want to run all the programs it 'fetches' into RAM.
I leave my machine on 24/7 but Windows is still designed that you HAVE to reboot regularly, if you are installing software, Windows updates, drivers etc. A lot of the time those require a reboot.
with modern hdd's and failure rate I don't think it makes any difference at all.
I find vista all though boots in about the same time, you can start opening software faster. Just because vista is caching doesn't mean you can't get on with work.
