Hi,
Just done the swap.
The drive that came out was an Hitachi, model:HTS543216L9A300. 5400RPM,sata-3gB/S.
The drive that went in was one of these...
http://www.overclockers.co.uk/showp... 7200RPM SATA-II 16MB Cache - OEM (WD3200BEKT)
So far...Im not really seeing an improvement... If anyone has a free program to benchmark a hard disk let me know and then we can compare this to a standard.
It seems louder, also, Heat and vibration can be felt through the palm rest, even in silent mode. I dont recall that with the original.
I think it will be back to the standard one in a few days.
so how easy was it? in the video they say need a little force, is there enough force you might break some bits or jsut hard to get apart.
i was thinking doing the same swap to the 320gb might just do 250gb tho
