This is a L737B440 ... and I note that it says 1.35V max on the box (I am nearly at 3.7GHz or so with that Vcore!)
Pneumonic's old chip is currently quite happy at 3.4 on 1.29v, although getting a little hot under a scythe mini ninja.
I plan to reseat the HSF with a little less thermal paste and try the fiddling with the fans this weekend to see if I can eke a little more from it in a SFF case.
Will be on a standard Asus P5K with 2x1gb Corsair XMS2 DHX 4-4-4-12
Is that the one I bought from you? It's a great chip, now running at 3.6GHz 24/7, less than 1.35vCore.mmmmmmmm L737B!
Mine was L737B505. They're certainly the ones to look out for.
If you ever decide to sell it can i have first dibsIs that the one I bought from you? It's a great chip, now running at 3.6GHz 24/7, less than 1.35vCore.![]()
How about 3.6 GHZ @ 1.3v 24/7 ? Higher .. lower ... lower ... higher ..
