Grand Theft Auto 4
Mikey.. Steam patched my game this morning. So I assume its out?
Unfortunately I can't load my save game file because of it :mad:
Bah.. this is narking me off. I shouldn't have to pay for a game and **** around trying to make it load the chuffing saves.
I checked the games cache via steam and it did its magic. Loaded up GTA and the GFX settings needed changing again, I tried to load up the save file and it once again said "Load Failed. Please check your hard drive and try again" game loads up from the very start at the boat with Roman.
I pressed escape to see if the save file was there, and it was. So I attemped to load from it and the error comes up again.
Is it confirmed that R* will release a second patch?
I don't think this is a patch because I got the patch recently via GFWL auto update, not Steam.
Sorry if this has been answered, not read the thread for about half a week.
Is the game broken or am I doing something incredibly wrong? On the last mission (if you choose the path of "revenge" rather than "deal", without giving too much away), is it actually possible to get onto the chopper? I repeatedly tap "jump" as much as I can without permanently damaging either myself or the keyboard, and it does bugger all. I eventually fall and fail the mission, is that right, or is the game broken?
This is like my 8th attempt now, every time I've failed at that point.
So they've officially announced another patch and it isn't just people assuming there must be one due to the outstanding issues?
Because some of their previous PC games never got more than one patch. San Andreas had various glitches at times like falling through the map. And the car wash never worked on the PC version (despite the one patch supposedly fixing that). Missing or badly out of sync audio in some of the cutscenes is another unfixed error which I remember encountering.
Are you talking about the bit when you're on the motorbike? You just need to hit the ramp at high speed and it should take you into a short cut scene where you grab onto the chopper.
There have been 2 SA patches afaik:
1.00
1.01
2.00
I hope they add AA to GTA IV :D.
Yep, after that point, when you are dangling from the "rails" on the underside of the chopper. It says to me "press SPACE repeatedly to climb into the chopper" (or words to that effect), and it NEVER works, hell even if I had a script to press space a million times in a second it still wouldn't climb up I bet :mad:
Ummm, I was given a bright orange Lamborgini by Bernie (The Poof) lol - It was parked hidden in some alleyway
I saved it at a safehouse but then crashed/destroyed it, how do I get it back/find another one?
I thought if it saved it, it was there for keeps??
I've tried running system restore back to when the game was loading up my save files properly but to no avail.
I can't find anyone else with the same problem as me on the steam forum :(
Dunno if this has been posted yet. But Gametrailers have done a 360 vs PC comparison. The PC specs are pretty top-end, so its a good test:
http://www.gametrailers.com/player/43929.html
The PC version certainly is much sharper and has more detail, no doubt about that. But you can notice the frame rate issues in parts. Its just disappointing that you need a very expensive PC to run it full and at a decent FPS.
hmm, odd. Don't remember having an issue there. Though i was playing on xbox with a pad.
Are you pressing up at the same time as you're hitting jump? Seem to remember you had to push up on the stick as well to make him climb on.
That PC is higher spec than mine but the game runs smoother than that for me. Maybe nvidia cards are smoother than ATI in this game?
Was stuttering and pausing all over the shop on the PC, 360 version runs much better.
Although saying that, it runs fine for me on me 4850, so id say somethings wrong there.
Have you tried setting the sliders to the same as they are for the 360 version? That is the only way to get a proper comparison of the two respective systems' performance. The game doesn't stutter and pause for me like in that video.
