What is your VID Rating - Q6600 Post here!!!!
24 Oct 2002
Portsmouth
Vid rating = 1.2625v according to coretemp.
Clocks to 3133Mhz on stock voltage, but needs a little boost to go beyond that. It's currently running at 3.5Gig using 1.425v in the BIOS which is about 1.4v with vdroop.
RaV
RaV
17 Dec 2007
Ireland
1.3125v running at 3.4Ghz.(425*8) - not sure if thats max overclock though. will try 400*9 in a min.
1.4v or 1.39v in bios and 1.344v in windows
13 Nov 2007
UK
VID = 1.2625V
In BIOS it's set to 1.2625V
Voltage dampener on and speedstep crap disabled
currently running at 3.2Ghz (8*400)
Have only run prime with it for an hour so far, I should run it overnight to make sure it's perfectly stable at that speed/voltage.
Caporegime
8 Nov 2008
As I type : Q6600 3.4 (seems stable) VID = 1.3250, Core Voltage = 1.552 V :(
I must admit I haven't set the voltage to manual, left on auto, simply because to have the confidence to do so I'd need one of my more technically literate friends to come round and show me. If I press the wrong button I could nuke the planet! :D
OP
26 Oct 2008
UK
So many people are useing 8x multiplyer and makeing it ''look'' like the CPU is faster??
what is the same speed when a cpu is at 345x9 compaired to XXXx9
I cant get anythin faster from my cpu at 3.096ghz at 1.47volts.
But i can when i go 8x multiplyer. What should i be doin?
Cheers
Hoper santa was good to you all! :)
OP
26 Oct 2008
UK
just like my cpu :(
