GTAIV R* benched my Quad @ 3.7GHz, gfx max everything except ‘textures’ set to medium, and view distance was adjusted accordingly to stay within gfx card memory limitations. At the following res results are as follows:
-1024x768 = 59.89fps
-1280x1024 = 56.28fps
-1440x900 = 54.67fps
-1600x1200 = 46.47fps
-1680x1050 = 46.38fps
-1920x1200 = 40.16fps
-1920x1440 = 35.89fps
Obviously knocking about 7fps off each result for in-game; since R* benchmark is not the most testing compared to some heavy in-game action, which fraps shows all too well. In-game fps I find it runs fine up-to 1680x1050 or 1600x1200, and never dips below 34fps (via fraps), any higher res the game suffers as in-game action heats up.
That’s very surprising, when compared to what I’ve read about equal spec pc's to yours running GTAIV at simular very high res. Still, if true then good for you.![]()
Its annoying me that I can't play in 1920*1200, is there anything I can do to get to this res? Its running at 1680*1050 at the mo and won't let me go higher, its only showing as 512mb of V-RAM, is there anyway to get it to use/see all 1gb of the RAM on my X2 card?
Just put the new Nvidia Drivers on, btw.
Cheers
Dave
It doesn't really have 1GB of VRAM, they just double the number on GX2 cards to make it seem better.
What are you doing to get such good FPS? I run at much lower settings than you and I have a better system, and I get around 15-20 FPS if I'm lucky
No he has the better system, his cpu is far higher clocked than yours and he has a heavy overclock on his card which prolly makes it as fast as a GTX ( remember he's got the G92 chip not the G80).
But anyways, 20 fps is too low, I get higher fps on a q6600 @ stock.
Are you patched up and have good drivers ? And turned anything in the background off that uses any noticable cpu power ?
I have a lower spec than you and get far better fps than that. You are either running at a very high res with high settings, or there is something wrong.
Do you own a Ati card as they dont seem to get on with GTAIV, if not then are you using the latest Nvidia 180.84 drivers? I've not plucked the fps results out of thin air and assure you they are genuine...
I'm running at 1400x900, even though my native res is 1680x1050
What in-game settings are you using and what do you get in the benchmark?
I run at 1280x1024 which is less pixels than 1400x900 and get 45fps in the benchmark (both CPU and GPU at stock) and in-game is usually at least 30fps and can be 50-60fps during the day.
at 1400x900 i get an average fps of 17
On an Intel quad @ 3GHz and 8800 GTX? Behave![]()
I have an 8800gtx
I dont know your pc specs, if simular then i would guess something driver related is amiss...
