got some stuff to go into my a05b today, nothing substantial, but it's a start!
overall view
PSU
it's the gigabyte odin 550w (GT...as for some reason the GT is cheaper than the standard version at OcUK).
i've mounted it fan down, not only because this gives it plenty of breathing space for the 14cm fan (as opposed to trying to breathe through a hard drive bracket
) but also because of the vented side of the odin (had it been the other way it'd have a mass of cable restricting it.
i have two concerns about the PSU, the wall socket connector it comes with is a 2 pin with a hole for the wall socket mounted ground cable (which i believe is European?), now i have plenty of kettle cables, but is it safe to use the PSU with an English cable? i can't test it myself as i have nothing with which to test it
AND it's motherboard connector is ONLY 24 pin (not 20+4 like most NORMAL PSU suppliers (stupid gigabyte!)
keep an eye out for a nice C2Q setup with either 4 (but probably) 8 gigs of RAM and a 260 GTX (or equivalent price GPU) during the next couple of months (might be quicker if i can get a job any time soon
) (probably getting the mobo and RAM this month, after that it's all up in the air!)
oh, and my cat opening a christmas present (for the lulz):
thanks for looking
