Very nice repton. Really like those speakers and that sub is just HUGEEEEE
Thanks!
Still tweaking and running in the sub at the moment! Sounds a bit polite.
What settings are you using for the PX80? Im just using the HDTVTest recommended settings. Seemed dull at first, but now look really good.
Planet Earth blu-ray on Ocean Deep episode looked amazing. Blacks were really good even during the day and looked even better with the curtains closed.
i use the HDtest settings but i've knocked the sharpness up one as it improves text and theres less blur on the image. This is noticeable on PS3 menu's
Yea i did the same. HDTVTest's sharpness for HD is 0. Kept it at 1 for both HD and SD cause it was annoying having to constantly grab the Panasonic remote and change it. Looks great anyway.
Also, should i turn the BD DVD 24hz setting to "ON" or keep it at "AUTOMATIC"? And what do you have the RGB setting at? Mines on "Limited" atm.
Cheers!
I use RGB Limited and Automatic for 24Hz
K cool. One other thing, i have read a lot of people talking about setting their "Black Level" to Low.
I can't find this setting on mine. Is it just on the PX80u model?
i haven't got that on my menu's......hmmm
Could be just the American model. Talked about on AVSForum (US), not seen it on AVForums (UK), so it must be just the 'U' model.
Ye probably.
BTW, with RGB set on full, you get "crushed black levels". Limited is better.
I see, thanks for the tip! Contrast controls the black level doesn't it? So raising it would make the blacks grey?
Wow.Some new and some old...
http://farm4.static.flickr.com/3466/3180522146_ee5920e926_b.jpg
Amp - Yamaha DSP-A1
Media - Sky HD
Games - Xbox 360
PJ - Sharp Z-21000
TV - Sony RPTV 48"
Speakers - B&W CD7 SE
Sub - SVS Cylinder
Ill try those out.
Only thing that annoys me is there is a buzz from the tv. More so on brighter scenes, but seems more audible today. Does it get worse if the tv has been on a lot?
