When people here post the weights they are doing for bench/squats and so forth are they including the weight of the bar?
Yeah it's standard for measurment of lift, just don't cheat! Average standard bar with collars is 12.5kg oly bars are 20 with collars
I believe they are 8 kilos.
They'll be a olympic then.
I was tracking my progress just using the weights I put on a barbell, should I change this to include the weight of the barbell?![]()
Why when you ask someone to spot you do they ALWAYS insist on touching the bar even when you don't ask for help.
I just assumed people didnt because you cant lift without it! Means my bench press and squats arent too bad then.
I dont touch the bar but my hands hover near it so I can grab it quickly if I need too.
