Only when you're spending time at Her Majesty's leisure![]()
It would be my first offence so id only get a caution.....
Until USA accuses you of terrorism by hacking the CIA to setup a zombie computer there.
lulzDDoS attacks, they are petty and noobery.
its just people who want to look cool because they cant hack, so they throw a bunch of junk at the server.
its like the big dumb guy breaking into the house
"duuuuuuh, umm, i can't pick lock, i break lock, guuuurrrr"
Sadly it isn't as simple as this otherwise many botnet owners would be behind bars by now. There will be another smaller botnet which gives out the attack commands to the main set of attacking drones. I think that luck plays a big part in taking down these script kiddie idiots out there.
anyway, what does ddos stand for ?
Oftentimes it is that simple, sure the smart ones use a secondary botnet (or just a open wifi connection) but some script kiddie with grudge against OCUK isn't necessarily going to be smart. But yes, luck plays a big part and they tend to catch the dumb ones, the smart ones are in other countries and are near untouchable to be honest...
Really hope something comes of this Spie. Can't live without the forums.
they could send some serious <ahem> your way !!!
In the past if memory serves me right someone who got banned was sending out mass emails to members of the forums?
Hope its sorted out quickly
You aren't being serious are you?
