Wow...very nice.
Are you supposed to remove the foam from the speakers?
Ive have some F4's and have left the foam in ...are they supposed to be left in?
Thanks
Remove them mate.
Wow...very nice.
Thanks
). I'm such a lazy toad. I had my lounge extended together with all the speaker wiring in place, bought tv and amp 6 months ago and still haven't got round to auditioning speakers!!
Thanks again for all the positive feedback. TBH until my sub comes I'll run Audyssey and tweak
My understanding was that the fronts should be directly at the outer edge of the screen.
But research and googling shows that its not all set in stone.
My view is that I will widen the two fronts to allow better stereo sepaeration when listing to music etc...
But some on the preset surround sound listening modes sound sooooooo good with the 876
Think I will maybe bring them out wider..
This is a good link..
http://www.dolby.com/consumer/home_entertainment/roomlayout2.html
How did you hide the speaker cable?
In your other photo, whats with the curtain?
what curtain?
The one on the double doors?
Loving that pic, really shows off the setup.
How are you finding the height of the screen? I thought you were supposed to have the center of the screen around eye level?
Ah its a door
Did you do all the work yourself, did you use a sparky at all?
Looks tops, whats the final cost?
Moved the speakers now.
I prefer it
Yeah, looks better. Where are you planning to put the sub then Easy?
I'd be having it in between those fronts somewhere if I was you.
I prefer it
Not sure.
What ever gives the best performance....
I was planning to have it to the left behind that pillar where the radiator is now...
