Yeah was glad I did mine yesterday when it was niiiiiice![]()
nobody has the "correct" answer to the question of what to use in your snowfoam.
Most people on detailing world prefer to use a snowfoam, myself included.
Dont think theres many that use hyperwash. But PB finds it works for them.
anyone used this: http://www.cleanyourcar.co.uk/washing-and-drying/super-spray-hose-end-sprayer/prod_335.html
seems like a good cheap alternative option to a full on foam lance? getting good reviews and all...
Hd foam Lance and some Snow foam will be arriving tomorrow
I should get out more I am actually getting excited about this coming![]()
I trust PB over any other detailers![]()
why ?
just because PB are good, doesnt mean there word should be taken as gospel. For a start, they use a hot water pressure washer with water at 40 degrees. This will drastically increase their cleaning power, meaning you may get the same results as them using a cold water pressure washer, requiring different products ...
Got mine last week from CYC, currently trying different mixes, 50% snow foam,30% Megs Gold Class and 20% hot water as a mix. Works alright.
Do you not just use the snow foam then ? or have I missed something from what you said I am now guessing you have to mix it with your regular shampoo ??
I thought you used snow foam rinsed of then used two bucket method and shampoo??
