YepI take it you gave MS feedback about all that so it might get fixed?
Does Google Chrome work ok in Win7? I went to install it and it complained about an issue so I didn't do it. Really missing Chrome![]()
Didnt work for me. Is chrome still in beta?
C:\Users\USERNAME\AppData\Local\Google\Chrome\Application\chrome.exe --in-process-plugins
Having a mare with permissions at the moment.
Last week I couldn't download anything using Firefox because my download folder was locked.
Yesterday the Firefox update couldn't install itself because Firefox.exe was locked and I couldn't delete it because I didn't have permission. The installer had removed most of the previous version so I ended up having to install it to a different folder.
This morning Windows decided to lock my Vista partition which meant I couldn't boot in to Vista. Had to do a start-up repair with the Vista disc to allow me to use it again.
Seem to be getting more and more file and folder locks and it's just become annoying to use.
Going to format and just install Vista and wait until Windows 7 is released before installing it again.
Where can I get this latest build
Where are you guys getting these latest builds from? I don't understand why they don't come via Windows Update, don't the new bits need testing?
Ok, and where are you getting them from?
Sources cannot be said here. But easily found if you look around a little bit
Running 7057 now, upgraded from 7000. Took the cd key I used for 7000 & all is working great!
Much difference? Is it around 3.2GB again in size?
ok cheers. Am I able to upgrade from build 7000 or is it a complete installation?
