I came back into here to find out what size torx driver you used, only to be sadly let down when I noticed that you didn't, and used pieces of straw instead!
T6 Torx
Pieces of straw! That nearly beats the customer PC someone brought into ******* when I worked there (many moons ago while a student) with a HDD "installed" using Blu-Tak!
Pieces of straw! That nearly beats the customer PC someone brought into a competitor when I worked there (many moons ago while a student) with a HDD "installed" using Blu-Tak!
Obv. 4GB RAM. Next step is an SSD slot in the expansion slot.
I have just put a 320 gb Scorpio Black in my MBP (3.1) I can only hear it reading / writing if it is very quiet. I decided o to a fresh install rather than CCC / Super Duper it - I forgot how long it takes![]()
Can you even hear it spinning? Mine sounds like a fan whirring away.
How are you finding it for noise? I have no idea how loud the stock drive is but I can hear the Scorpio Black whirring away all the time, I really thought it would have been quieter.
