Thanks for your reply Parxuk, that is valuable information to me.
I think I will definitely get the Saitek Pro range, just need to shop around for a good price, OCUK seems to be out of stock anyways. Just one thing that worries me a little. After doing some checking on the Saitek range, as well as the Go Flight range, esp the MCP Pro, I am worried about compatibility. I presume all your hardware runs fine on FSX? I use Vista 64, just need to make sure that won't cause a problem. I did read in a few forums that some hardware addons to FSX like the Saitek range, although works fine with all detault aircrafts, it has a lot of trouble working with 3rd party addon aircrafts. Now I use a lot of freeware and payware aircraft addons, any ideas if your Saitek & MCP Pro works fine with other craft apart from default planes?
I think I will give TH2GO a miss for now, happy with TrackIR and the 40'' LCD but maybe next year. But the MCP Pro looks fantastic and if you say its brilliant and have no compatibility problems with other aircrafts then I think I may put that on my wish list too
. (and perhaps the GF-46 too, that is, once I can afford it
Thanks again, look forward to your reply.
Soya
PS. I discovered this just yesterday, you may not have seen this yet,
http://www.simviation.com/cgi-bin/yabb2/YaBB.pl?num=1236299941, havent had a chance to test it to see if it indeed makes a difference, but from reading the forum on that, looks like many people seem to find it very useful.
