DIY bods in here - redundant light switch
It's the hallway of my basement flat, I don't think it's a junction box, that picture is overexposed and doesn't show the hole in the middle of it. You can however see the dimple where the hole is in the second picture
I think it is an old ceiling light thing where you can dangle the wire through the middle, it looks the same as some of the live ceiling light things (sorry don't know what they're actually called)
Like a pull cord switch for bathrooms?
So I'm guessing the lights have been replaced with their own switches?
The lights that exist now are connected to a different switch, one of those dimmer switch things, which is just a couple of feet to the left of the pictured (now redundant) light switch.
No I don't think so as we've said I think it's an old light fitting that would have at one point dangled from the ceiling.
I actually think a switch looks better than those blanking plates. When we moved in here we randomly had a phone socket on the landing at about switch height. I got a blanking plate but it just looked odd to be honest. We've since decorated and I covered it up with ply and then filled it.
I'm right in guessing two lights have been taken down? With it being a double switch and the cabling seems to run to the right in the ceiling space, to another rose?
It looks as though a light at some time has been removed or never actually fitted when the house was built or rewired.
Just make sure you wire it up the same as the switch and you should be OK, and yes choc block is a standard term for a connector block.
You're right it is a double switch, I can follow the wire off into the distance, but it seems to dissappear somewhere upwards further on. So I have no idea what that would connect to.
This did used to be a big old house once upon a time, so who knows perhaps I control the upstairs flats lights, lol :p
Blind leading the blind... Why would you put a choc box which wont fit btw in a back box and blank it over?
all you need is a 5amp connector block connect the cable's together and fit said blanking plate, failing this get a qualified sparks in.
WTF are you on about. Is that not what i just said:confused:
Edit. Choc block, not choc box
and a diyer telling a diyer what to do imo is the blind leading the blind.
I'm a qualified sparky.
Its probably conected to next doors lights, sending them Barmy with lights flickering.
Personaly i would use
image.asp
CHOCOLATE BLOCK ELECTRICAL CONNECTOR
Then the blanking plate, thats what i did in my parents hall.
When we had council fitting new heating system we had a redundant socket, Plasterer decided to remove it poke wires inside wall and plaster, im sitting on pc and lights the lot went off, went down and hes franticaly trying to unfill the hole " CLOWN"
EDIT: Just remember if you are going to have a jolly about with it all get the corect rating of hardware, dont want a new post saying damn house caught fire
