Hi guys,
Just started to OC this, as I said its my first attempt at overclocking so just taking it step by step. Had a few problems before as nothing I set in BIOS to OC was being accepted, so flashed to the latest version and we are OK now. Ive knocked the FSB from 266 to 278 so its now at 2.5ghz. Idle temp is approx 37/38ºc. Load temps however shoot up to late 60's.
When I was at stock 2.4ghz, load was 60, should upping the clock speed 100mhz be pushing the temp up nearly 10ºs?
Not sure if anyone is familiar with the bios on my motherboard gigabyte P35C-DS3R (F10 bios). But when you change the cpu clock speed it says in flashing red that you should set system voltage control to auto - so i did this. Should this be set to manual, as Ive always thought with overclocking you only move the voltage when the sys becomes unstable? Im thinking that if the voltage is being controlled by the system, then when prime95 rapes the cpu its pulling more voltage than it needs, and putting temps up?
Any tips guys, cheers
