- 13 Jul 2004
- Stanley Hotel, Colorado
You can get pci cards to stack ram into as well I think
Should be ok but it isn't as compatible as normal XP. Particularly drivers for peripherals.
If i were you i'd consider Vista 64. Works excellently with 8gb of ram.
gt
id deffo sy windows 7 7057, im on it at home and its stable as a rock, only thing i havnt managed to get working is 4OD which doesnt recognise WMP12so i cant watch skinns haa haa.
asides that its great![]()
I recently went from 4GB 6400 to 8GB 8500 (seeing as its so cheap atm).
There isn't much difference but the system seems to be slightly snappier.
XP maybe old but it is proven technology, the number of problems and incompatabily issues in vista is amazing, even with microsofts own products (Word etc), I'm not sure what 7 is like but scene as its a beta means that there could be unknown problems people haven't found yet.
Do you run your 8500 at 8500 (1033 mhz) or on a divider? Last I saw it wasnt possible to get 8GB to run at 8500 speeds?
What's your sticks and setup otherwise as it's something i'm interested in certainly.
Im currently using 6gb of ram on 2008server 32-bit. It detects all 6gb of ram
(still only 3.5gb is usable per program running).
Will be changing back to windows 7 soon tho, just needed to play with some hyper-v stuff.
really its up to you, if you don't mind vistas problems go for that, if you don't mind maybe losing data or having to rebuild the system, or maybe having some compatability issues go for windows 7 if you need something stable go for XP64bit
