Presently @ 3.4 with mine too.Thanks r0zvad just tryed again at 3.4ghz and seems fine now at 1.4v. Have ran OCCT for an hour and the max temperature it reaches is 53 degrees so im guessing this is ok. Would a new cooler be needed do you think? Would it be quieter?
Chip voltage is 1.4v and under water i'm returning idle temps of 15-17c (11-13c before i get the open fire going in my lounge) and load temps (OCCT 100% load) of 22-23c.
Understand the temps look low but this is confirmed in realtemp and coretemp too which is odd.
gt
How far can you get with everything else at stock settings and using only the cpu multiplier ?
it sounds like you've got a poor clocker chip and if that the case theres not much u can do about it..bringing the thread back lol, sorry for the bump
i've spent absolutely ages trying to clock my 940, but i still cant get it above 3.4, and that was just by upiing the multi and the volts a little
i've tried 3.5 with the following settings:
HT reference: 235
NB Multi:10x
HT multi: 9x
CPU vid: 1.45
NB link: 1.25v
NB core @1.36v
cpu multi: 15x
ht voltage: 1.3v
all spread spectrums disabled etc, cool and quiet is switched off, ive turned off all auto settings apart from some of the memory which i thought i better not touch
with ram set at 667 mode so it doesnt overclock, and timings of 4,4,4,12 with 2.1 V, its also running in ganged mode
it doesnt matter what i try i cant get it stable at this speed, and ive looked at the various guides on the websites and tried what was suggested, so any help would be greatly appreciated
u could get a better cooler then put the vcore up to 1.5v.
also try unganged mode
u could try disabling cpu prefetching but i highly doubt that'll help..yeah thats what im starting to think as wellthere are more options in the BIOS which im not sure about, for example would disabling cpu prefetching help things? ill try unganged mode and see where that gets me, if not ill shell out for a new cooler
tbh keep it under 60c. 55c is fine but anything over 60-61c can cause problems. amd site says 61c max..thanks for the replies so far guys, i fiddled around with unganged mode and cpu tweak and it didnt really help stability at the same volts unfortunatelyI think this one is just gonna need more volts to reach the higher speeds. Under prime's large ftt test its becoming very clear my cooling isnt up to scratch, and dolk's guide says anything above 55 can cause phenoms to become unstable so i guess more cooling is necessary. Can anyone recommend me a decent/the best cooler around for this kinda job? i dont mind attaching fans etc if need be
Having a bit of problem getting my Phenom II 720BE rig stable even at stock.
I wonder if someone could have a look and see if anything is obviously wrong.
Cant complete an hour of OCCT and infact turns itself off.
Complete System Spec is;
CPU: Phenom II 720BE
MOBO: DFI 790FXB M3H5
MEMORY: 8GB of Corsair XMS3 DHX (4x2GB)
Those temps are at idle, but taken directly after a fairly long prime 95 test.
On load CPU reaches 50ish and system stays about 40-45, a little warm but nothing outrageous.
