Do a completely clean reinstall of adobe cs4Okay so I've installed Illustrator CS4 but when going to the File menu it bombs out saying that the Adobe Version Cue DLL cannot be found. I've checked (in both Program files x86 and normal folder) and its clearly there. Any ideas?
dunno then mate, may I suggest googling around looking for people posting on forums with similar problems... that's what I do when I have an issue that I can't work out on my ownI have, numerous times. It's defaulting to C:\Program Files, so I'm going to try C:\Program Files (x86)
Still nothing...
dunno then mate, may I suggest googling around looking for people posting on forums with similar problems... that's what I do when I have an issue that I can't work out on my own![]()
I've seen some people say that renaming the update folder from 4.0.0 to 4.0.1 works but its still not working
Photoshop runs fine though despite requiring that same dependency
All this cr*p for a feature that I won't actually use.
