- 18 Oct 2002
- Manchester
Windows Start button -> All programs -> FAKE FACTORY CM9This might be a stupid question, but how do you get it to run?
Thanks, I've just realised I've installed the update and not the mod...Windows Start button -> All programs -> FAKE FACTORY CM9![]()
Error said:MountAppFilesystem() failed: You don't have all GCFs needed to play this game.
OK guys downloaded this earlier this evening, and I'm getting an error on launch.
Interesting, as it launches fine from Steam, and the installation of BASE+HD+9.51 went smoothly with no errors etc.
Any guesses?
Do you own episode 1 and 2?
If not you need them for this to run.
Yep, should be able to uninstall over the top...think theres a mod folder it hides in so could delete that too. Nowadays with the newer version theres an uninstaller.
Doh only have HL2+EP1. Bummer.
Where is the best place to download the 9.51 update?
How do i get this mod to work? i dowloaded all the files and the new update,
i installed it, i got hl2 and epi 1 an epi 2, and they are installed.
when i click on Windows Start button -> All programs -> FAKE FACTORY CM9 the game loads but i dont see the new Alyx, what im i doing wrong?
Last time I installed this I couldn't notice the difference. I'm guessing I didn't install it properly![]()
