HOW DO I BUILD MY PC NOW IVE BOUGHT ALL THE BITS?
They plug into a cable on the PSU.
Those 4 pin plugs are usually used for hard drives, so your PSU will have the correct plugs.
the side doesn't need to be on.....now go press the button to see if it boots :o
After 5ish seconds it will prompt you to hit del or some F key to enter the bios.
No it's best to boot up with the case sides off so you can actually see what is and isn't working.
Switch on and then press the delete key.
tick.tock.tick.tock - 24 sound track
do i need to put the case back together before switching on?
and once i switch on, pending all going well!, how long will the BIOS take?
Better to leave it off for now so that you can diagnose problems...
As soon as you plug the power in an LED should register on the motherboard indicating that the motherboard has power .... This is a good sign.
