i clean mine using car wash equipment from the car wash next to work, that way i dont pay for nething.
nething?
Oh lawd.
nething?
Oh lawd.![]()
Its probably in the thread earler on, but where do you get them from?![]()
ur just jealous cus i get ma car washed/vacuumed all for free lol.![]()
I've already got two buckets + microfibre mitt. Can only really use a hose at the moment (problem with water pressure on outside tap so jet wash doesnt really work)
I have the following on my list to buy
Wheels
Bilberry for cleaning
FK1000 for protection and hopefully easy cleaning in the future.
Need a alloy brush so what would you recommend?
Car
I have some autoglym car shampoo + 2 buckets and microfibre wash mitt.
Polish/Wax not sure - its atlas grey, whats fairly easy to apply by hand but offers good results?
Is Blackfire Midnight Sun Ivory Carnauba Paste Wax any good?
Roof
Is 303 cleaner and fabric guard the best for softtops?
Interior
Grey leather mostly so what would you recommend.
Any other recommendations? The wheels are a bit of a nightmare to clean at the moment so I want to get them really cleaned and then protected which should hopefully make them easier to clean in the future.
Thanks
Hi mate,
What lance do you use? Mine is crap as well and gives the same results as mrk's.
Can anyone recommend some basics to me?
I wash my A3 reasonably regularly, but would like to do it a bit better. I have a chamoise, 2 buckets and some (old, cheap-ish) wax.
What products should I spend my money on if I decided to use about £30/40 or so?
