dude i want more pics!!!! - subscribed![]()
Anyone know of a place I can get lots of cheap, relatively strong acid? Not sure where to get it and any regulations - was told by a car bits shop that they can't sell battery acid (~35% sulphuric acid) these days. I could probably make do with distilled vinegar but it'll be expensive for the amount I need and take a long time as it's weak.
at JonJ's mains AC idea! In words of Sergeant Wilson "Do you really think that's wise sir?"have you thought of heading down the scrap yard and enmptying out some batterys? im sure the scrappy wont mind you having the old batteries to drain, at a price of course. even a diluted amount will be stronger than vinigar
That was a very detailed reply, thank you man. I'm studying engineering, but fluid dynamics is not my strong point. I'm very glad you've run the numbers on it before starting manufacture, any estimates for the heat it can dissipate?
Getting flux up to temperature in 6 minutes shouldn't be a problem, whack the oven up to full temperature until it finishes warming up, then swiftly put the copper into it. If it doesnt fit then no luck though, which is a shame. I hope the blowtorch works out for you.
Bit more ambitious, and in several ways a quite stupid idea, but you could heat it electrically. Mains ac will make things quite hot. I succeeded in welding a small piece of aluminium with it before the circuit breaker went. Mains ac hurts mind, and passing current through a large copper block will be considered unsafe.
Regardless I look forward to the next update
It's a painfully slow process of putting the heatfins on, deoxidising etc.
I am becoming more intrigued on how the soldering is going to be done as it looks to me that getting all those plates to line up and pressed into place is going to be a very tricky job, which will get harder as you put more plates on and the thing stiffens up, unless everything is absoutely dimensionally **** on. Have you considered making the holes in the plate a fair bit larger to make fitting easier, then using copper washers to bridge the gap? You could offer a plate up to the tubes, clamp it up, put the washers on, draw round each washer, take everything off, solder the washers to the plate in the exact same position, so that when you offer up the plate again it should be tailored to the tubes. Just have to use washers which have a inner hole dia close to the tube OD. With the plate in place solder the washers to the tubes, the washers may well unsolder themselves form the plate while you do the second solder run but if you clamp the plate and do them one at a time it shouldn't matter. Then repeat this for the next plate.
edit: Just thought how my idea could be improved. Why not fabricate your own squaure washers using the flat plate you already have. Cut the plate into squares, coat one side with flux and seed with solder so you have a square of copper with a film of solder on one side. Then drill a suitable hole in each washer. Pre-soldering each washer removes to need to put the loose washer on and draw round it, you should just be able to put the pre-soldered washer on the cooling plate as positioned on the tubes, and blast it with your blow torch. The solder may even run around the tubes as well, though it will probably still be necessary to put an additional ring around each tube. The key benefit of this is you can enlarge the holes in your cooling plates so that they will be more forgiving to any measurement errors.
, so it has an outer box lined with plastic sheet a mattress came in - now it's in the styrene tray to avoid cutting up the plastic lining:
A few of the first fins are a little bent as well, though they'll be mostly out of sight behind the motherboard tray.
