Btw, does anyone have any experience of brazing copper, or soldering copper radiator innards? I'm making a copper rectangular box so need to attach the sides by soft soldering with tin/silver/copper solder (96%Sn,3.5%Ag,0.5%Cu) if I can - I presume that galvanic corrosion won't be a problem since Copper and Tin are close to each other on the reactivity table, but if anyone thinks it will be a problem or has experience please let me know! I'm not sure the blowtorch could get anywhere near brazing temperature (~850C) but hard soldering with silver solder may well be possible (650C ish) since the propane/butane blowtorch is rated at getting copper pipe to around 650C. Alternatively, a friend has a TIG welder... but I'm not sure that is sensible and don't want him to hand me a melted lump of what was once a radiator!
I'm nearly done with making the radiator - 69/74 fins done so at the ends where the plenum/manifold will be.
I decided to go the route of having a copper rectangular box at the top and bottom for the manifold. It won't be as pretty as acrylic block, but trying to get a good seal and screws in the 5mm edge around the pipes just doesn't seem feasible, unfortunately, and I have 4 copper fins that haven't been drilled to use, so no extra cost. Plus, time is against me, and a copper manifold is quicker and easier to make: I need to finish this project before the end of the month really, as I'm moving for my job and won't have access to tools.
I'm getting a friend to mill holes in copper cylinders for the inlet, outlet, fill port and drain port this weekend hopefully, which will then be tapped and joined.
