what about on win 7?
I've not tried Win 7 (can't be bothered with 3 OS's!)
From what I've heard though it does run better in Win 7 than Vista.
Thanks for the XP info guys. If this true then I will be pleased that I bought and installed XP last week to boot along with Vista. I will try this out when I get home.
wunkley we have very similar setups other than you having a 4870 X2 which I think does not make as much difference as it should, as the cpu appears to be the bottleneck.
I do not have a problem with the fact that I cannot run the game on the highest settings. I do however take issue with the fact that turning everything down makes little or no difference (3fps). The engine appears to have limited scaling capability which I think is big mistake for any game no matter the niche market.
is that a PS2 game? umm im sure my iphone could run that game whatever it is
is it me or as you get further and further into the game it gets laggier, regardless of where you are?.. It's either that or by lowering some of the settings ive actually decreased performance somehow..
This guy seems to be getting 10fps less with Windows 7.
win7 186.18drivers arma ver 1.02 = 5198
Hi wombraider, did u have any problem getting the 186 drivers to install on W7?
I havent read the whole thread but I hope you can destroy the buildings and terrain for realism.
I hope you get a sniper rifle!
Hell, i have had a building come down on top of me! and yes, i have seen trees "taken out" too![]()
