Trixter said:It says its 1.5 metres but you gotta bend it and that takes a lot of the length away.
My window is about 2ft from the floor, the unit is as near to the window as it can be and theres just about enough pipe.
Might JUST do it i dont know
Need to drill for broadband wire soon, so maybe can make a bigger one for the pipe?
Trixter said:I think you will be ok but if you did decide to connect it up permanantly it does come with the fittings and bits ect for outside.
Another thing is noise, on full power when the compressor is going its loud, i dont know what it would be like downstairs vibrating through the floor if its upstairs, im in a bungalow so im good![]()
Apart from that its great though.
The pipe isn't the longest, but it does come with foam to block up your window around the pipe as well as the fittings for permanant fixing and a remote control.
Dolph said:Ok, all picked up and set up. It's a lot cooler today, but after a quick 5 min blast it rapidly brought the room temperature down. Unit's quite small and slimline (which is nice), a little noisy but you can't have everythingThe pipe isn't the longest, but it does come with foam to block up your window around the pipe as well as the fittings for permanant fixing and a remote control.
All in all, well worth £165, especially as the same rated unit in B&Q is £199 and quite a big bigger in terms of space.
I'm happy![]()
Bit worried about the small pipe, after my room is done i wont be able to have it right under the window
HighlandeR said:And there I was about to order off a £5.95 USB fan from fleabay.....
Bumping an old thread here, but no point in making a new one with so much information, so where can i get an exhaust extension pipe from? I've found one here But £45 is a bit expensive for what it is, so has anyone got any links or shops?
Well it's that time of the year again, I've just purchased one of these units,
These are only £99.99 from Homebase atm, for that price I thought it was worth a punt, I should hopefully receive it by Monday/Tuesday and I'll post up a mini review.
We got the same one a few weeks back when they were cheaper.
Noisy, but it's nice and chilly in my room now.![]()
£45 does seem a bit of a rip off...
I found one cheaper on Ebay but it still seems quite expensive for what it is;
http://cgi.ebay.co.uk/Air-condition...3|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
