The 3.5 release is RC3.
What sites are you talking about? There's a bug with fixed backgrounds being jerky, but that takes some heavy lifting to fix.
I know RC3 is the release version that's what I stated and well even this forum seems to not scroll as smoothly as it did in Firefox 3.
Scrolling on some sites seems to be a lot more jerky than with Firefox 3, was hoping they would fix that, but 3.5 final is the same as RC3 so guess not.
working fine for me, apart from a few unsupported add-ons.
System Restore doesn't, AFAIK, touch your profile. It'll have been upgraded and so strange things will happen. There'll be a pluginreg.dat or something you'll probably have to delete to make it pick up on Flash.
Scrolling aside (if it was happening on every page, I'd suggest it was an issue with your profile/configuration than Firefox itself), what else was "totally useless"?
%APPDATA%\Mozilla\Firefox\pluginreg.dat
That definitely sounds like some issue with an addon. I'd have suggested sticking with 3.5 and fixing the problem.
Edit: or pluginreg.dat inside your actual profile (i.e. replace pluginreg.dat in the above path with Profiles\[random alphanumeric].[profile name]\)
Is that a Windows or Firefox setting?It's exactly the same as it was in 3.0 for me. I'm guessing you're wanting to strange smooth scrolling that IE uses? I personally scroll 3 lines at a time.
Quite liking this release. Much, much faster at Javascript than Even the latest Opera 10 beta builds.So Fastmail and Gmail load up quicker for me.
Don't know if I'm being stupid, but I've searched everywhere and can't find the pluginreg.dat at all.
