Halfords sell most of what has been recommended here but colinite etc are from www.cleanyourcar.co.uk
The washer is from your nearest Range store!
Yes thanks Overlag I do know how to clay a car
I went through 200G of Bilt Hamber Auto Clay aka 12 quids worth today (I can't recommened this stuff enough btw, you do not require any sort of "Quik detailer" you simply use water as the lube instead). That picture was taken after "treating" one panel....
It really was a sorry state I had a lot of industrial fallout on the car as the previous owner worked at the railway and parked up near the lines at the station I'm led to believe.
I'm going to order some more clay up and give it another going over, 95% has been removed though I'm very pleased after 4 hours yes 4 hours claying. Removed a serious amount of crap from the car today, so much that the new box of clay had to go straight in the bin. My mate who's a detailer is going to machine polish it for beer money when I'm ready.
Apologies if its already been covered, but does anyone know of a UK based establishment that imports Porter Cables?
Cba to import one myself![]()
I'm liking the look and the results from the Werkstat Acrylic Kit so I think that might be on the shopping list, but what sort of shampoo should I team it with? Is it worth going for the Werkstat Auto Body Wash or are shampoos all much of a muchness?
This thread has been a thoroughly entertaining read but a mightily confusing one at the same time. There's loads of great advice in here but there's so much to take in it's hard to know where to start. But having ploughed my way through it on a number of occasions I think I might have picked up enough along the way to take a stab at what would be the best combination of products for my car - an '03 Focus in Machine Silver.
The price of all these new goodies soon add up but I'm willing to pay out to ensure I get the right stuff, first time. So with that in mind, what other bits and pieces do I need, bearing in mind I'm pretty much starting from scratch and I'd like to give my pride and joy some serious TLC during its time with me.
I got some Bilberry wheel cleaner through SoliD the other day and it's pretty intense, cleans the wheels to a nice shine quickly and painlessly. Also the snow foam is cool, just need a lance to do it properly
All you need really is:
--In order of application--
> 2 buckets (£2 !)
> A decent shampoo (£3-£5 for a large tub of Triplewax)
> A decent washmit, not a sponge!! (£5)
> A hose or pressure washer (I would recommend the Nilfisk 110.3 after buying one recently after it was recommended to me) (£39)
> A Microfibre drying towel (£5-£10)
> A polish, Autoglym super resin polish for example (£9)
> A sealant or wax overcoat, Autoglym extra gloss protection for example (£9)
> An alloy wheel seal wax or spray, Autoglym Alloy Wheel Seal for example (£5)
All that will cost you around £80 but consider this a long term investment. The SRP and EGP will last you at least a year, the shampoo the same and the pressure washer while cheap, is better than competing brands that cost almost double and can be used around the house too but if you have a pressure washer or decent hose already then you saved £39![]()
What's Concorso? Sounds rather posh!If you are going for the Werkstat, I'd go for the shampoo as well. There is a noticeable difference in gloss when the car is dried between the other two shampoos I use (Poorboys Slick and Megs Hyper). Since topping with Concorso, the Megs gives better results.
Oh, that's your GT-R. I thought I'd seen it somewhere before, albeit not looking quite as a shiny!If you are buying from Rich, check out his Show n' Shine section![]()
Buckets of elbow grease and access to an unlimited supply of water, And, er, that's about it.As far as anything else you require, what do you have to start with?
anyone finding it problematic to wash there cars at the moment? Its far too hot so i cant really do it as the car will dry itself in seconds leaving streaks etc. Then theres the polishing and waxing. the products want low temps but the body work is probably in the 60s at the moment....![]()
