- 28 Nov 2008
- UK
Interesting you say that you had no difference in your S430. My dad has an S350, 8/9 years old, and it makes a big difference to his MPG (measured tank to tank) on motorway runs.
Diesel - when you say your Skoda runs like a bag of crap on regular, in what way exactly?
If your Octy is running like a "bag of crap" on normal unleaded I'd get it taken in and looked at.
It's got maps for 95 & 98 RON fuels.
If it's having problems with the lower octane fuel I'd say you've got some problems with the vehicle.
Really?Halfords oil will do pretty much the same as Castrols finest
Most likely, yes. Do you think Halfords drill for, refine, and process their own oils?Really?![]()
in reality the 1.8t in the vRS is known to run rough at start-up for a minute or two.
Halfords oil will do pretty much the same as Castrols finest, just like Asda petrol will do pretty much the same as V-power.
Just to add to this, I had to fill up the other day with Somerfields Unleaded, for days until I filled up again with V Power the car struggled to start properly, misfired at cold and generally boggyness. Whether this was the petrol or something else I am not sure but it seems weird the only time I stick some supermarket fuel in it acts weird.
I severely doubt it. However, they do choose who their supplier is, and that supplier is almost certainly not providing the same quality oil to Halfords that is going in to Castrol Edge, for example. It's kind of like saying there's no difference in quality between a Proton Satria Neo and a Mini One, because they are both rated to 120 mph.Most likely, yes. Do you think Halfords drill for, refine, and process their own oils?
Same happens to me with Somerfield fuel.
[TW]Fox;14446004 said:Your car is broken.
