I have 1300 pounds
AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz (Socket AM3) - Retail £149.99
x2 Powercolor ATI Radeon HD 4890 Plus 1024MB GDDR5 PCI-Express Graphics Card £291.96
MSI 790FX-GD70 AMD 790FX (Socket AM3) PCI-Express DDR3 Motherboard £129.98
Corsair XMS3 DHX 4GB (2x2GB) DDR3 1600C9DHX Twin3X (TW3X4G1600C9DHX) £65.99
OCZ ModXStream 780W SLI Ready Modular Power Supply £59.00
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) £36.98
Thermalright Ultra-120A Extreme CPU Cooler (Socket AM2/AM2+/AM3) £34.99
Sony Optiarc AD-7240S 24x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £18.99
x2 Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM £27.96
Total £827.36
Then a case of your choice.
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle £539.99
x2 BFG GeForce GTX 275 OC 896MB GDDR3 PCI-Express Graphics Card £319.98
Coolermaster ATCS 840 Classic Case - Black (No PSU) £169.99
Total : £1,177.98
The board does not support crossfire.
I am not sure but can you give me what sort of style case are you into and i will find the best one for you.
well a case with good cooling is what i need. i live in a very hot country.
haf 932 looks nice antec 1200 looks nice lian li armoursuit looks nice...
how can u understand if a mobo supports crossfire or it doesnt?
im going with
the 2x 4890
noctua as the cpu cooler.
i7 is for sure.
western digital caviar black 500gb
corsair hx 750W(or 850 not sure)
thats ok right?
still need to decide for mobo and case
i havent left anything left out have i ?
You could knock off £200 and get a half decent water cooling system, it would be worth it. I think there are some graphics cards with water blocks built in anyway.
Pointless, video cards with waterblocks already attatched cost far more than a card with stock cooling.
how can u understand if a mobo supports crossfire or it doesnt? im going with the 2x 4890
By googling it and doing some research, in fact it might be a better idea to do your own research as some of the advice being given here is pretty poor tbh.
the gigabyte GA-EX58-UD5 board in the i7 bundle can support both crossfire and sli setups so you'll be fine with 2 4890's
and the haf has brilliant airflow and its a good sized case so all your components will fit in easily
I just had a look over OC's site and put together this quick list of parts for you to consider. Its under your £1270 budget and I have taken into account the parts you say you allready have. Hope this helps. If its any help I would go for this as my rig and I would be well happy with it. Sorry for no pictures but for some reason I cant get them to post.
Product NameQtyPriceLine Total
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle£539.99
(£469.56) £539.99
(£469.56)Options applied to the above product:
3.80GHz Overclock£0.00
(£0.00)£0.00
(£0.00)
OCZ Z-Series 1000w Modular '80 Plus Gold' SLI Ready Power Supply£177.99
(£154.77) £177.99
(£154.77)
Gigabyte GeForce GTX 275 896MB GDDR3 PCI-Express Graphics Card£154.99
(£134.77) £309.98
(£269.54)
Antec 902 Nine Hundred Two Ultimate Gaming Case - Black (No PSU)£89.99
(£78.25) £89.99
(£78.25)
Western Digital Caviar Green 1TB SATA-II 32MB Cache - OEM (WD10EADS)£57.99
(£50.43) £57.99
(£50.43)
Sony Optiarc DRU-870S 24x DVD±RW SATA Dual Layer ReWriter (Black) - Retail£23.99
(£20.86) £23.99
(£20.86) Sub Total : £1,043.41Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout)Shipping : £12.50VAT is being charged at 15%VAT : £158.39 Total : £1,214.30
cant wait until dx 11 gpus im afraid...
two gtx 275's or two 4890?s ?????
well i live in cyprus and in summer it gets up to 50 degrees very very rarely. but the thing is i wont be using the computer in the summer since i go holiday. but i can say its still hot...
