- 22 Mar 2009
If it's stable then what's the problem?
Yes, very true said. My pc is stable so far but I think I need to run linx up to 100 times with 8 threads to ensure it stable overnight.
Someone metion me that overclock 4Ghz at 1.184vcore is very bad indeed ? is that true ? They say best on safe side is 1.26 to 1.30vcore ?
LoL, who told you this??
Low voltages is a great thing!!
I was amazed at the low voltages you are using... then I noticed you have HT disabled!!!
I don't understand why some people disable HT.. what's the point in having i7 if you don't use HT???
::edit::
You will be extremely lucky if you can have a stable o/c with HT enabled with such low voltage as this... what is your QPI voltage set to?
whats a safe temp for the i7 to run at then?
nice, give intel burn a go now!
Nice, you can be sure it's stable now. That's a nice overclock and I bet it's not too loud as the fans are below 1500rpm.Just done that. All passed sucess! with 75 runs on 8 threads
Bulldog, what mobo and HS are you using?
How the hell are your volts that low?
