Never used the backwards compatability...kept almost buying GoW1/2 as only played chains of olympus on the PSP but they are being released on Blu-Ray and GT5 is almost out now so no need for PS2 games anymore.Sorry if this has been asked/answered already, but if I "upgrade" to a Slim, is there an easy method of transferring my saves from my current PS3? Also, all of my downloaded games/content - what do I do with that? Login on my PSN account and download everything again? Has anyone done all of this yet with minimal hassle?
Info on how to use it:
Playstation UK said:PC Update - Visit eu.playstation.com for the very latest version of the update data. Follow the on-screen instructions to download to your PC.
To transfer the update data to your PLAYSTATION 3, save the file to a PS3 compatible storage device such as Memory Stick, Memory Stick Duo, USB drive or PSP.
Before starting, use your PC to create a folder named 'PS3' on the storage media or USB device. Within the folder, create a folder named 'UPDATE' (This folder name is case sensitive and must appear in all capital letters). Once the UPDATE folder has been created, download the PS3 system software update to this location.
Once the update data has been saved, disconnect the storage device and connect it to your PS3 via the slots under the slot cover or the USB connectors depending on the device you're using.
Once connected, navigate to Settings on the PS3 Home Menu, select [System Update] and then [Update via Storage Media]. Select the connected device and your PS3 will install the update data stored there.
ps3ud0You have to download firmware 3.0 from the website, copy it to a USB key or drive - specifically in a file/folder hierarchy of PS3\UPDATE\PS3UPDAT.PUP
Then shove the key into your PS3 USB port and hold START+SELECT together.
Thanks guys! And one more (probably answered) question:
How much are the highstreet stores offering on PS3 Fat trade-ins? i.e., how much would I have to pay, CASH, for a Slim today?
We can't say names (against the forum rules).
If you ring around most high street shops are matching trade-in prices. Most users here have found a place which is offering £198 for a 60GB fat, so they're playing the high street retailers against each other.
Have a read of the thread for more info..
Just tried it with the supplied HD (already on FW3.00) and it didnt do anything when I booted up either with or without the USB cable connecting the DS3...You have to download firmware 3.0 from the website, copy it to a USB key or drive - specifically in a file/folder hierarchy of PS3\UPDATE\PS3UPDAT.PUP
Cancel or get a refund and just buy it elsewhere?![]()
Can I ask why?
Sorry to be nitpicky, but is it really a good idea to have a surround speaker resting on the PS3? I've read that speaker magnets can mess up other electronics but even if it doesn't do that it'll mess with the heat dissipation surely?
