ok, but: no dediated GPU and its a dell oh and its second hand... so not really
lol at least you have the OCUK community to do your thinking for you![]()
Not sure which way to turn at the moment?
For general gaming is the 1GB ATI® Radeon™ HD 4670 a better performer than the 3670 512mb?
Also Dell don't seem to say what resolution the display is on the 15.6" (inch) Truelife 720p HD WLED Edge to Edge Display? I'm assuming 1366x768
yes i beleive so.
if you want to get one, why not do this:
buy this:http://www.dmxdimension.com/recommend/N00X1602 add 256 SSD.
When it arrives, strip out the SSD, sell in auction site, then replace with normal HDD.
Overall cost:
£799(laptop) + £240(SSD upgrade) = £1039 - 5%(with voucher) = £987.05
sell SSD = £987.05 - £400 = £587.05
Replace HDD + £60
Total cost of ownership = £647!
SPEC:
Intel Core 2 Duo P7350 2.00 Ghz
Vista Home Premium
15.6" Truelife 1080p Full HD WLED
4096MB
1GB ATI Radeon HD 4670 DVD+/-RW £979
£799 N00X1602
The default res is 1920x1080. Sounds like you havent got the RGB screen if you cant increase you res. Drivers wont make a difference, even on default W7 drivers it would pick up your native res
