[TW]Fox;14834725 said:Yes an E46 with completely different sized wheels will look silly.
[TW]Fox;14834737 said:If you are earning so much money that in under a year you will be able to afford £40,000 worth of E92 M3 then why buy a 325i to save a couple of hundred quid on insurance
Confusing thread is confusing.
Different sized wheels ! It will look like a Silver Cross pram.
Cant understand how you would moan about £300 extra insurance yet stick wheels on that will need £700 of rubber?
Painting it pink with a 9" roller will make it stand out, does not mean it should be done![]()
the difference between a 325 and 330 is what less than a second?.
[TW]Fox;14834934 said:Have you driven either of them?
but I'm not in it for the straight line speed
I just want enough power to be able to unsettle the car around a corner
[TW]Fox;14835030 said:So why spend 40 grand on an E92 M3? £20k gets a nice 330i.
Are you some sort of wannabe drift hero?
And no I'm not a "wannabe drift hero", but I do enjoy sliding BMWs around corners and having a bit of fun in industrial estates, I don't want to sound pompous or anything but I'm not exactly bad at it.
You are going to get eaten alive for that comment!![]()
Just how good can you be at drifting an open-diff'd car around?
I enjoy unsettling my cars too, but its just not practical nor communicative enough to hold a decent slide.
[TW]Fox;14835204 said:It sounds like my advice about the sort of people you should avoid buying a BMW from is irrelevent as you seem to fit that bill
Fake rimz, industrial estate burnouts all you need now is your mate from Brum to service it with Morrisons oil and its sorted.
why do all bmw's have high miles *sigh*
