[OcUK Staff Builds] rjkoneill's TJ07
yeah - i finally managed to source a side panel
after a few emails to Silverstone in Germany - a new one arrived [around 60euro]
Annika @ Silverstone helped me out and got the panel to me quickly
many have said that the TJ07 has specific panels that fit the individual case the panels ship with due to how it is made
looks like i was in luck as mine fits perfectly
planning a mod that involves changing the window so it is mounted on the inside of the case
I know a man that makes different back panels for this case rjkoneill :)
Good to see your taking your time with this build and its looking good :)
Subscribed :D RJ can you tell me how to wire the front USB ports on the TJ07 case to the motherboard?
I'm looking to upgrade to an i5/i7 system soon and want to use the front USB ports on my case
I'm just not sure........use to a solid block rather them being separate and read somewhere that you could damage your motherboard if connected to the wrong pins :eek:
make it match the front of this...
i used heatshrink to keep mine in position ready to be plugged straight in
its EK
can be found on their website - its a new product
i ordered two - and a black mounting bracket for my EK supreme
it looks very nice in all black and a set of BP fittings pointing out of it :D
i need to find a nice looking way of mounting it [preferably black allen head bolts] as i dont really want to use the stock moutning kit as it looks a bit fail
a mounting kit like the heatkiller would look far better
I got some that were 30mm long, M3 and M4 ones for mounting fans to my rads. What length/size would you want? Ive got some spare and sure I could manage to send 4 haha. The top 10mm or so isn't threaded on them but dont think that will be an issue here?
no it wouldnt
the m3 ones would be brilliant if you dont mind - i havent even got a clue what to look for tbh
would they fit through a motherboard mounting hole?
