35Kg per arm is a massive amount for a dumbell fly! Very impressive. How far down do you go? Chest level?
I come down to about chest level. Form is a little shakey at the moment. I will check exrx for form but from what I remember, I believe I am doing it right.
Ah, just checked. Dumbbell press not flys...doh!. Arms too bent. Right, have to reassess that one, sorry
. Meant to be flys not press.
Regarding right arm being much stronger than the left, I am having the same problem and it doesn't feel like they could ever become equal. When I fail, it's my left arm that fails and I feel like it's holding me back, but I must resist the temptation to increase the weight on the right arm as your body will end up looking very uneven.
The difference is such for me that when I've done 8 reps on the bench press and the left arm fails, I could do another 8 reps straight away with only the right arm. Quite annoying really.
I thought they evened out a bit but from Wednesday I was surprised how different they were especially with the flyers (press).
The Craig said:
You can shoulder press 30kg dumbbells
can also lat pulldown a bit more too
also the dumbbell fly looks a bit off 35kg
all in all though looks like good progress to me.
I am working on shoulder pressing 30Kg dumbbells. Just upped from 25Kg 3*8. Only manaaged 4,5,5 first attempt. Very hard and the left shoulder was really burning. The lat are very hard and I am at around 8,8,6. The grip is killing me
. The fly as established is a dumbbell press. I will correct form (and weight) tomorrow when I go back for my 3rd weights session this week. Thanks. Nice to know the progress is reasonable. Means I am not doing too bad
A2Z said:
Im assuming your 'Shoulder Dumbbells' is the TOTAL of the db's, ie 2 x 15kg?
Bit confusing, normal for BB to put the total INC bar, and for DB to put weight of each.
Nope, the shoulder press with dumbbells is 30Kg per dumbbell. Not able to do 3*8 yes as noted above but have done 3*8 with 25Kg and that is after doing the 30Kg military press with the barbell.
The numbers are per dumbbell or extra weight with total weight in brackets for exercises using barbell or plate machines. Bench press is 40Kg extra weight (2*20Kg plates) or 60Kg total inc bar weight. Dumbbell shoulder press is 30Kg per dumbbell.
The order of exercises in the sheet is usually the order I do them in. I alternate between bench press / lats / military press / fly to give the muscle groups more time to recover whilst working on a different set. Doing my military press straight after the bench press sees much worse results for the military press for example.
TheCybermonkey said:
HAHA....Had a moan at the misses this very morning as I was feeling a bit tired and Im getting quite precious about getting some good sleep.
She has a habit of watching the simpsons in bed while im trying to get to sleep...grrrrrrrrrr.
On earlies this week so wasnt best pleased.
Shift work can be a killer. I remember my time doing it.
My wife keeps coming home with Japanese / Korean / Taiwanese dramas and will quite happily sit there until 3 am watching them. She is almost as hooked as I can get with a great game on the PC or XBox. Ok she is worse. I usually stop at 1am
I think I will re-asses my form on all the exercises just as a matter of course as I feel form can deviate if you don't check it every now and then but I am fairly sure the rest should be pretty good.
Oh and the 55Kg dumbbell rows are also getting hard, mainly on the hands again but although I can do 3*8, it is currently only 8,8,5 with good form (quick up, 2-3 second controlled lower. Up pull without body roll).
I like the bench presses, squats and leg presses best with the military press coming next if I could only just get past the 8,8,6 or 7 and then left arm failure.
One other thing. Grip for the bench press (barbell). Where should the bar be resting in the hand ?. Mine is resting in the curve between the bottom of the thumb and the first finger which is directly above the wrist to create a vertical line up the arm. Only problem is that on my left hand, moving m thumb around after a weights session is a little uncomfortable like the thumb had been pushed too far in a direction.
Cheers
RB
