SLAMMING OR NOT??
29 Aug 2009
Hello guys,
Thinking of ordring this kit from overclockersuk.
Intel Core 2 Duo E8600 LGA775 'Wolfdale' "Overclocking E0 Stepping" 3.33GHz
http://www.overclockers.co.uk/showproduct.php?prodid=CP-232-IN
Foxconn BlackOps Intel X48
http://www.overclockers.co.uk/showproduct.php?prodid=MB-015-FC
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit
http://www.overclockers.co.uk/showproduct.php?prodid=MY-043-GS
What do you think?? A SLAMMING system or NOT??
Cheers
23 Apr 2009
Cheshire
Short answer, not really.
You would be much better getting an i5 750, a P55 board and the same RAM. Also, make sure you get a good CPU cooler and a powerful graphics card.
RJC
RJC
Don
29 May 2005
Kent
Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - Retail £159.99
(£139.12) £159.99
(£139.12)
Gigabyte GA-P55-UD3 Intel P55 (Socket 1156) DDR3 Motherboard £106.98
(£93.03) £106.98
(£93.03)
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) £67.99
(£59.12) £67.99
(£59.12) Sub Total : £291.27 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.00 VAT is being charged at 15% VAT : £45.04 Total : £345.31
Personaly I would go I5 or AMD.
Done a quick spec above :)
9 Sep 2008
Glasgow
Fail
Win =
Product NameQtyPriceLine Total
AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz (Socket AM3) - Retail£154.99
(£134.77) £154.99
(£134.77)
Gigabyte GA-MA790XT-UD4P (Socket AM3) PCI-Express DDR3 Motherboard£105.00
(£91.30) £105.00
(£91.30)
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM)£67.99
(£59.12) £67.99
(£59.12) Sub Total : £285.19Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout)Shipping : £9.50VAT is being charged at 15%VAT : £44.20 Total : £338.89
OP
29 Aug 2009
Ok, cheers guys...
One thing i need the E8600 as that is the best processor for my needs
do you think the board and ram are a good choice for the CPU??
Cheers
OP
29 Aug 2009
Yes, i have been using FS9 for over 8 years, my experience tells me that the E8600 was the best (i did have an i7)...
So that is the CPU i will go for, suggestions for a mobo and ram would be great :)
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
The E8600 is a total waste of money. The E8400 is a lot cheaper yet only 330mhz slower. Unfortunately it's out of stock at the moment but the same applies to the E8500, £55 cheaper but only 170mhz slower. Both overclock like demons.
In any case, building a 775 rig from scratch now is foolish. Core i5/i7 or AMD is the way to go.
Did you actually have a i7 rig as you were only posting about overclocking possibilities on the 15th September and a "special cooler" that does'nt fit i7 out of the box.
OP
29 Aug 2009
FS9 is single threaded...
I had an i7, the only thing i was going to upgrade was the mobo, ram and cooler (and pastymuncher, if you check their site you'll find an adaptor for the i7)...
Apparently FS9 was designed around the time when E8400's where brought out, due to this they are more compatible with the game, i have tested this for myself and find it to be true...
But i am stuck on a motherboard and RAM....
Cheers
22 Mar 2008
The question begs, why by an e8600 when you could save £££ and overclock an e8400. Having said that I personally would be more inclined in buying new tech since more future releases will be optimised for it - my ten pence
21 Jun 2009
Chester/Loughborough
Do you still have the i7 ?
I find it hard to believe that an i7 at 4GHz wouldnt perform at least similarly to an E8400 at 4GHz.
Its rather silly to buy more 775 stuff especially at those prices.
+1 for i5 or i7.
23 Apr 2009
Cheshire
Let me first say that I know very little about flight sim games, but my question is : Why invest in £350 worth of last gen kit for Flight Sim 9 when you could be using Flight Sim X and be using current tech kit (I read that X has multi-thread support). Or is there a particular reason for sticking with FS9?
OP
29 Aug 2009
There is a reason for sticking with FS9, this is that all my paid for aircraft and scenery is for FS9.
FSX is multithreaded, but this does not mean more gaming performance it simply means that 1 core if for 3D rendering and 1 for Finalizing...
I was just asking for the best mobo for a E8400, E8500 or E8600....
23 Apr 2009
Cheshire
P5Q deluxe is great. If you want to save some money, the P5Q Pro Turbo is very good and will likely meet your needs well. IMHO these are better than the X48 board as these P45 overclock well, use newer tech and require cheaper DDR2 RAM.
