Jagdesign - Have you got anything near the button of the monitor, I only have to wave my hands infront of the button and it lights up.
Yes; the monitor is dithering a lot harder to match into sRGB, but the U2410 is way better than my other monitors. I've tried sRGB colour matching my Dell E248WFP on the PC, and so much dynamic range is lost, you loose a *lot* more than 6 levels on that; almost all the shadows crush to black when done on the PC!Have you actually checked the visual effect the U2410 sRGB mode has on images? At least on mine the sRGB mode gives dark greys a dithered look (easily visible on squares in the lagom.nl black test), it makes the first 6 or so squares on that same black test invisible, and it tends to "dull" the picture more than I'd like too, and it doesn't totally solve the wide gamut - it just makes it a bit better. Still better than the alternatives, but not perfect![]()
Hello all.
I rec'd my U2410 from OCUK on Saturday. It's absolutely terrific, except for the - to my eyes - very obvious green on the left / pinky red on the right tinge issue. If I'm gonna be using this monitor on a daily basis I can't tolerate such an obvious difference between the two sides of the monitor.
It's such a shame as there are no dead or stuck pixels, and the lighting appears to be very even indeed! Lovely blacks.
Anyway, I thought I'd mention it here as having read this thread through not many people who ordered their screen from OCUK have experienced the problem. I think I'm the exception that proves the rule! I'm gonna give Dell a call in the morning and get them to send out a factory sealed replacement.
Anyone know if Dell pick up the faulty screen at the same time they deliver the replacement? I don't want to be without a screen whilst I wait for a replacement.
Yep, although with careful tweaking you can get very acceptable colour results in custom mode without the black crushing. That's why I'd advise everyone that, unless you want a matched sRGB/Adobe mode for printing etc, you're probably best off running the U2410 screen in custom colour mode and tweaking to taste. You can use the Adobe/sRGB modes as a guide to help you balance the colours in custom mode properly, then you have the best of both worldsYes; the monitor is dithering a lot harder to match into sRGB, but the U2410 is way better than my other monitors. I've tried sRGB colour matching my Dell E248WFP on the PC, and so much dynamic range is lost, you loose a *lot* more than 6 levels on that; almost all the shadows crush to black when done on the PC!![]()
I agree, this screen is definitely good enough to last the next couple of years. Although some people mention OLED, I still doubt it's realistically on the horizon for a 24" screen in the next 5 years, which means the only likely improvements in the coming years will probably be LED back lighting and 120Hz operation. Although they'd be nice to have they're not deal breakers for anybody I don't think, which means there's little reason to hold off buying..I'm probably like you, and still waiting for a "perfect" monitor, this will do for another couple of years though. Hoping that my next one will be wide-gamut, but with a larger than 8-bit transfer, and with colour correction native on the OS. With a larger than 8-bit transfer, can do correction in software without loosing dynamic range.
That's good to know, I had a look and saw the little alignment line you were talking about, so it's nice to know it's just a simple screw driver fix.Seen lots of people complain about Dell stands, now that I took one apart, it's a real simple fix.
On the box.. check the label isn't underneath another label.. it should still be there, maybe just hidden underneath.Well it's going well so far, not. I contacted Dell, who didn't recognise the serial number on the monitor (CZ-... etc)!!! They said contact the reseller (OCUK) to get their order number - or batch number or somethnig... and then Dell will be able to help.
EDIT: And now the 'work order', which OCUK should be on the box... isn't.
EDIT: Dell say that I need OCUK's invoice number. So... back to OCUK.
Buying EVERY screen is a lottery to some extent unfortunately. Unless you go to the very high end screens which cost thousands, not hundreds.so buying this screen is a lottery?
NEC have a 24 and 26" IPS screen available. (the 2690WUXi ). Expect to pay more.. quite a bit more.i'm interested in a 24" screen for photography/post production work, not so much interested in response time as I plan to do very little gaming.
trouble is i'm not forking out if there's a chance of a duff...which sounds likely from this pink/green tinge issue.
are there any viable alternatives?
The Work Order number is a 9 digit number.. No letters, just numbers.I'm gonna phone OCUK back and get the supplier company, then.
They tell me they can't get the invoice number without the work number. There are no stickers ontop of other stickers.
Could you tell me what work numbers should look like? How are they composed?
