Overclocking the i7 920
OP
30 May 2009
Maidenhead
Yeah no wonder it was crapping out :p
To be honest, I'm surprised it even BOOTED at 3.8GHz with that voltage! Haha.
Btw, what's a safe QPI voltage? I have my system running @ 4GHz now, with 1.325V on the core, and 1.64V on my RAM, and QPI set at 1.36V. That sound ok?
Going to have to leave this for tonight. Time for work sadly. Will continue to overclock tomorrow afternoon from around 2ish.
OP
30 May 2009
Maidenhead
Only firm rule when overclocking the i7 is do not have more 0.50v difference between the QPI and RAM voltages else damage can occur.
If this is the case, then you can surely set QPI voltage to 1.6V then, esp as most RAM runs at around 1.5-1.65V. I have mine running at 1.64V. But if max recomended QPI voltage is around 1.375V or so, then that 0.5V rule can't be massively important.
OP
30 May 2009
Maidenhead
Only overclocking to 3.2Ghz? Ouch mate. Make sure you set those voltages properly. Don't do what I did mate. I thought I had a crap chip too, but I was doing wrong voltages (1.13V instead of 1.3V on Vcore). Even a bad chip should surely be able to make 3.6GHz + I would have thought?
Keep trying mate. Don't give up.
Anyway. Today is stress testing day for me.
OP
30 May 2009
Maidenhead
What would be the best combination of programs to run to test my i7 @ 4GHz?
There was a good post the other day, about what to run, but I can't find it anymore sadly =(
Edit: So, I just run 50 cycles of LinX. CPU passed at 4GHz, in 14 mins 50 seconds.
Temps not going over 80C on CPU. That is with the side of my case off for now (just in case anything goes wrong). Need to tidy up the cabling, and close it back up, but hopefully it shouldn't change much. Don't have any real airflow into the case on the side when the side isn't on, and room temp, is around 22C.
Idling at around 40-45C currently.
Those temps sound ok?
18 Oct 2002
N.Devon
The temps are very fine. Linx doe'snt really work the QPI or RAM just the cores themselves so something like Prime95 on blend would test that.
OP
30 May 2009
Maidenhead
If you bought the overclocked bundle from OC themselves, I would be very VERY surprised it doesn't work. They aren't the kind of people to send you a dud setup. I thought the guys there said not to fiddle with settings if they clocked it for you, but to send them a webnote etc?
