- 25 Jun 2009
- Middlesbrough
Panel looks real good quality. I've enjoyed reading this build. Cracking work.
the little button head screws make it look superb
Yeah. They come with the window kit
mines very similar and im thinking of going white tubing as i have a tinted window like you (though i had to get it cut and i have an extra hole cut so my top RAD can get some air), will the white tubing show up under UV lights?
did you use 1/2 tube?
and what sort of temps are you getting, tempted to get a quad RAD but only if it will knock a bit off of the temps.
im not keen on uv cathodes though
