Radeon 5850 and a box of tissues, thats what I use for my sexual issues.
Niiice, I'm waiting for the Asus voltage tweak version though![]()
My HIS, don't take the mick outta my Acer board![]()
I'm about to try the MSI afterburner, I'm not sure if I would want to increase the voltage (don't like the risk) but I am going to overclock right now! Hopefully I can get 825mhz and a good increase on the memory
I read something about the 5850 having overvoltage protection built in? and that if you push the memory too far.. you actually won't realise as there is no artifacting and you'll get less FPS.
With the ATI Radeon HD 5800 series we’ve implemented a hardware-level overvolt protection scheme where a signal from the regulators can be fed into the GPU directly and the GPU can take action if the regulators indicate they are operating out of their specification. In the unlikely event that such a scenario happens, rather than the board turning off, the GPU is designed to clock down to get the regulators back into a normal operating zone and then clock back up when they have done so.
As mentioned in the HD 5870 article, overclocking the memory on these cards is quite different from any other card so far. Normally you'd expect rendering errors or crashes, but not with these cards. Thanks to the new error correction algorithm in the memory controller, every memory error is just retransmitted until everything is fine. So once you exceed the "stable" clock frequency, memory errors will appear more often, get retransmitted, but the rendered output will still look perfectly fine. The only difference is that performance drops, the further you increase the clocks, the lower the performance gets. As a result a normal "artifact scanning" approach to memory overclocking on the HD 5800 Series will not work. You have to manually increase the clocks and observe the framerate until you find the point where performance drops.
My Powercolour one has arrived. Shame my CPU is being RMAed at the moment (quality service so far from OcUK BTW) so I can't even test it out
Box contents is pretty spartan. The card, a million-language install leaflet, cross-fire connector and dvi-vga adaptor. Oh and of course Dirt 2.
Can't wait to get my CPU back to give it a whirl![]()
