Well, I have been using a Gillete Fusion for years now, probably since I started shaving...
When I first started to shave(years and years ago) my skin never really used to get irritated, I would just shave normally and apply some Nivea balm after and hey presto no rash or uncomfortable feeling.
Fast forward to now, Shaving with the same Fusion(not the same blade
) and applying aftershave balm just doesn't cut it anymore.
Firstly, my stubble is so tough I have to make multiple passes over most areas which I think irritates some areas of my skin and secondly I'm never able to achieve a close shave at all. I use the Gillete Fusion gel, is this stuff generally crap?
Usually in the same area on my neck, where the stubble seems to grow back the next day, I get a rash which isn't very comfortable...
My method of shaving is.....:
-(sometimes) wash face with a facial scrub and hot/warm water
-apply gel
-shave(I try not to go against the direction of the stubble)
-wash face with cold water
-apply balm
Any tips on what I can do...I was thinking of ditching the Fusion and trying some bog standard disposables(recommend me some?)...if you have any suggestions to products or methods I can try please post!
Thanks
) and applying aftershave balm just doesn't cut it anymore.Firstly, my stubble is so tough I have to make multiple passes over most areas which I think irritates some areas of my skin and secondly I'm never able to achieve a close shave at all. I use the Gillete Fusion gel, is this stuff generally crap?
-apply gel
-apply balm
Thanks
