The Manly Shaving Thread
Status
Not open for further replies.
20 Jun 2005
London..
Well, I have been using a Gillete Fusion for years now, probably since I started shaving...
When I first started to shave(years and years ago) my skin never really used to get irritated, I would just shave normally and apply some Nivea balm after and hey presto no rash or uncomfortable feeling.
Fast forward to now, Shaving with the same Fusion(not the same blade:rolleyes:) and applying aftershave balm just doesn't cut it anymore.
Firstly, my stubble is so tough I have to make multiple passes over most areas which I think irritates some areas of my skin and secondly I'm never able to achieve a close shave at all. I use the Gillete Fusion gel, is this stuff generally crap?
Usually in the same area on my neck, where the stubble seems to grow back the next day, I get a rash which isn't very comfortable...
My method of shaving is.....:
-(sometimes) wash face with a facial scrub and hot/warm water
-apply gel
-shave(I try not to go against the direction of the stubble)
-wash face with cold water
-apply balm
Any tips on what I can do...I was thinking of ditching the Fusion and trying some bog standard disposables(recommend me some?)...if you have any suggestions to products or methods I can try please post!
Thanks
16 Oct 2005
Ditch the disposable and go for a DE safety razor, such as a Merkur. It won't irritate your skin at all unless you use it incorrectly.
OP
20 Jun 2005
London..
It sounds like your stubble is too extreme for a regular razor; you need to upgrade to the Gillette Fusion Gamer Power Razor.
Noo...more money on expensive blades!:(
I don't use a disposable, I have a Gillete Fusion...;)
I was thinking, sometimes I don't shave for a while, and my stubble becomes quite long making it harder to shave. Do you think shaving more frequently will stop the irritation or help it?
11 Jun 2005
Liverpool
16 Jun 2004
I find I get the best shave if I wash with really hot water and try and give my face a good soak with a face cloth!
If I don't do this then I get a bit of irritation.
17 Aug 2003
Woburn Sand Dunes
worth it when you consider the price of the blades - £4 for 10 or cheaper - and especially when you consider those blades last longer then the rip off fusion blades. They really dont compare to a decent saftey razor like a merkur
9 Jan 2006
Nottingham
i shave every 3 days as no matter what i do (I'm not gonna spend loads of cash on an expensive razor!) i get an irritation from the razor. i tend to wash face with some decent facewash and hot water, then dry it, then wet it again with hot water, apply foam and shave. i used to use the king of shaves gel but i found i started to get irritation again so i switched to that nivea foam stuff. i don't find i need to stick balm afterwards as i get no irritation.
17 Aug 2003
Woburn Sand Dunes
They arent expensive though. The razors might be 4 times the price but the blades are less than 1/4 the price of the fusions for example. they are absolutely worth it!
£4.50 for a pack of ten blades? http://www.mankind.co.uk/src/awin/Merkur-Stainless-Platinum-Safety-Razor-Blades-10-Pack-PRODMEAC1/ 45p a blade. Whats the average price for 8 fusion blades? The dont shave as well or last as long!
28 Mar 2005
Drunken badger punching
Decent and cheap Merkur razor:
http://connaughtshaving.com/merkur33c.html
Buy that and 5 each of Feather, Wilkinson Sword and Derby blades and whatever else takes your fancy, a cheapish brush and some soap/cream. Hell, even some gel from the supermarket will do without a brush, and you'll not look back.
I have the above razor, and it's brilliant if a little short. Doesn't take long to get used to it though, and it's just as quick for me to shave with that as a regular (crap) razor. A much closer shave with no razor burn whatsoever.
Avoid Gillette blades like the plague, and you'll be fine.
You do NOT have to spend a fortune on shaving gear to get much better results. A Gillette/WS cartridge razor 'Ultra Plus With Extra Fanny Magnet Titanium Ultra Sport GTX' is about 6 quid with a blade. 5 blades another 8 quids on top. That £19 Merkur razor + 100 Feather blades (the very sharpest and by far the best) blades will be about £40. You do the mathematical calculations.
Status
