- 3 Nov 2004
- UK
In the control panel under the AHCI driver what does it say? Msahci.sys or iastor.sys and what does it say for driver version?
Thanks, got it now. How does this tool work? I've tried running it in Windows and it just says there are no drives that the tool can be run on. Do I need to boot into a dos environment to run this?
Can you confirm exactly where I should be looking please?
You're not alone. It doesn't work for me either. Best just wait for Crucial's own GC tool I reckon.
Ah right, I'm using IDE mode, not AHCI.
Well that's very odd, you shouldn't have any issues with wiper running at all, try running at Administrator. Which version of wiper.exe does it say in the load screen?
Glad you got there.Run as administrator works perfectly thanks!
Ugh. I've got Windows 7 installed on my SSD. Am I right in thinking then that I have to install Windows on a completely seperate drive (which I don't currently have plugged in) purely to flash the drive back down to 1571, before going back up to 1819 in DOS?
Ridiculous.
Yeah, it's 10GB and included in my 18GB?
i want to know why they have put the price up to this £144.99 inc VAT
