That's pretty terrible :/ Even my Clio averages approx 35mpg a tank for a normal weeks driving
It's abnormal. The car is either broken or being raped to within an inch of its life every mile.
Given the above, my 2.8i Auto is remarkable, or that Mini is knackered (I fear the latter!)[TW]Fox;15454981 said:the Mini One I have at the moment is on 29mpg. Great, its a 1.4 ffs
That's very low. I take it you have been ragging it? My mum's get's well over 30 even when being ragged.
Yo negros.
[TW]Fox;15456556 said:Not really, its pretty slow though so you end up with your foot to the floor going nowhere half the time plus its all around town. This is the one issue I tend to have with underpowered cars - in something like your Z4, every mm of pedal travel gains an instant response from the engine. You end up being very careful with the throttle simply because if you are not, you'll be doing warp speed, or in the verge, or whatever. With super slow cars you often get little or no response from the engine when you press the pedal if you know what I mean?
[TW]Fox;15456556 said:know what I mean?
[TW]Fox;15456848 said:It's more difficult to chose the best amount of throttle. Apply a little throttle and you'll think 'I need abit more acceleration' so you apply more, but the problem is that acceleration never arrives so you end up appyling more throttle for no gain. Yesterday a diesel Zafira pulled away and I couldnt keep up![]()
OMG I TOTALLY PWNED SOME CRAPPY 530i IN MY ZAFIRA DIESEL DUE TO TORKS!!!112
I know what you mean, I am like that in my 1.4 Polo and was looking at moving to a 1.6 Mini but not if the fuel stats are like that!
This is what I found in the other half's old fiesta. You use the throttle a button on a playstation remote because any less than that and it does bugger all.[TW]Fox;15456848 said:It's more difficult to chose the best amount of throttle. Apply a little throttle and you'll think 'I need abit more acceleration' so you apply more, but the problem is that acceleration never arrives so you end up appyling more throttle for no gain. Yesterday a diesel Zafira pulled away and I couldnt keep up![]()
