never used it before and seems to get me £5 off this phone.Thought I'd show a few pics of my rooted pulse, running pandahome.
Love this phone, endless messing about![]()
How do you get it have contacts on one of your home pages?
Interesting.Didn't know you could do that.CheersI think you just hold down your finger on a homepage and create a shortcut to the contact.
So theres no downside or con to the tmobile pay as you go sims with the £10 unlimited texts and net ?
Not hit like a usage limit or anything ?
edit - Also anyone give me a quick run down of how the hell quidco worksnever used it before and seems to get me £5 off this phone.
I was liking my phone til it stopped working this morning.It's stuck on an eternal android screen loopI'm hoping the guys on modaco can help!
I think Tmobile state that there is a "fair usage" limit of aorund 40MB per day ... however, there's no extra charge - just if you exceed this limit (possibly on a regular basis rather than an occasional day) then they may send you warnings that your use may be excessive (or I think in their terms advise you that you are probably using the wrong device for that amount of usage) and then if "unfair use" continues they may put some limits on your access.
Also, using phone as modem for a laptop etc is against usage rules (and I think they say that they reserve right to charge for data usage if they find out you are doing that)
Just go to quidco and sign up then go to Tmobile site via their site. Basically lots of websites offer commission to other sites who direct people to them - quidco does this but passes on the commission to you ... only caveat is that they take the first £5/year to fund their operation etc so you wont see the £5 from Tmobile but then you'll get anything else for the rest of the year.
I signed up with them when I got my Pulse ... however, I had a double win as got it on the Tmobile 33% off day + quidco rate was £15 then! (It also happened to be my birthday as well!)
Can't really do anything with it I don't think.I can get onto the blue screen by pressing vol-,red key and turning it on but that's it.I've ordered a memory card writer and i'm gonna put the december update on that and see if updating it will help.Can you get it to boot off recovery image?
I think I had the same problem when I was trying to update and unlock my phone. There is a post over at Modaco which sorted me, but can't find it at the moment. I believe I had to copy over an update onto the memory card to fix it.I was liking my phone til it stopped working this morning.It's stuck on an eternal android screen loopI'm hoping the guys on modaco can help!
I'm going for that update option as well.Just got to wait for a memory card reader for my pc to arrive.
(To mount USB connect with cable then pull down the USB notifier on the top bar on the pulse and select the mount option
His phone is stuck on a reset loop so how can he do that?
Hadn't spotted that ... so it will need a uSD reader.
Its a real shame as we certainly won't see any rom updates from t-mob now.hmm looks like t-mobile have removed the pulse and are not selling any?
just been reading on forums that t-mobile have discontinued the phone already
also been reading that they are getting the LG InTouch Max (GW620) and the Samsung Galaxy Portal (i5700) this month![]()
