***The Official Core i3 Overclocking Thread***
Ohhhh, it seems I don't have a 1156 mounting kit for my Mini Ninja 2.
Do I just go and buy a H50? :D
i didnt think the coolers were any different. my arctic freezer 7 wont fit as is?
SUCCESS! finally.
Asrock HD55m Pro
2x4gb Gskill Ripjaw DDR3 2000
Core i3 530 @ 4.4ghz
im going to let prime run all night. it wont even break 70c... this is nuts for air cooling. the only problem i have is i cant even post when the ram is in dual channel. i have to put them in odd banks just to get to the bios, so all this is in single channel mode. dont know if its the bios, my ram, or just settings....
the e5200 on that chart would probably get around 7k @ 3.7ghz... and if you look at the i5 661 @ 4ghz you get a good idea where this i3 chip would be with 4.4ghz. so i guess it is about 7k to 12k when theyre both o/c'd heavily. thats nearly double the score!
Just got mine all built in a P180 Mini, H50 on the rear using the Antec fan on low blowing into the case through the rad.
Currently Priming at stock at 31/34 :D
That's while running the on chip GPU as well :cool:
i wasnt even able to install windows with the i3 video. i only succeeded installation once i plugged in my 8800gt, but its ok because i wasnt planning on using onchip video.
the are the DE FACTO htpc chips now. imo, you cant build a better system if going from ground up... the only thing its lacking is better onchip video.
Only just started mine mate.
Won't be getting anything decent from me for a couple of weeks, 'cos im going back to uni to do some exams but I'm not taking my PC with me. Coming back to get that when I've done exams. Plus I need the mounting kit for my Mini Ninja 2.
90C using stock cooler at the moment. I'll leave it for now until I get my mounting kit otherwise the thing will melt!
