thinking about it using the 2nd method around the middle of the sandwich I could insulate with some 3mm silicon rubber and arm flex tape, if I am not going to enclose the unit then I could consider sticking some copper finned heatsinks on the outside of the HX plates and having some airflow over the unit... the hot HX plates are never going to be sub-ambient so it could only help to remove the heat load..
I was planning on mounting the HX unit inside the case, but I think I may well have to look at outside mounting now as if its radiating I really don't want all that hot air inside. The idea of placing a number of my radiators, the HX and power units in a 'radbox' type setup is looking more appealing..
Of course I guess one could just use washers and nuts..
