Hey all :) // Help with a build..
Antec 902 is the only other case I would look at for similar cost and style.
I love my 902, hands down the best performing case I've owned (knocked 13 degrees of my CPU temps coming from a 334) the only thing is if you're going to lans you will see them everywhere ;)
Am I alone here thinking that the insides of most Antec cases are pretty nasty looking? The hdds mounted that way looks way too odd.
Im not to fussed on that to be honest, hey each to their own :p
The only reason I asked on the H50 is that it's 80mm isn't it :)
Pretty sure its 120mm.
A lot of people buy a pair of fans and run a push/pull air setup surrounding the radiators, and I am 90% sure they use 120mm fans and they fit the rad perfectly.
As above, yea it's 120mm. Comes with a 120mmfan so you could mount it and the case fan on either side (push/pull) for some cool temps :)
Ah yes, my bad, stupid me lol, I think I will go with that then :)
Will keep it at that then and see what happens with the case n gfx in stock
Club 3D ATI Radeon HD5850 1024MB GDDR5 PCI-Express - £223.99
Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - £143.03
Asus P7P55D Intel P55 (Socket 1156) DDR3 Motherboard - £118.99
Corsair TX 850W ATX SLI Compliant Power Supply - £97.27
Cooler master CM690-II Advanced Case - £89.99
Corsair 4GB (2X2GB) DDR3 PC3-10666C9 - £74.58
Corsair H50-1 High-Performance CPU Water cooler - £63.99
£690.95 ex VAT
£811.87
Yeah deffo :) will take pics for sure. Will most likely build it in the server room at work, I'll be in my element then :p maybe at home depends what day it gets delivered xD
Thanks so much for all your help dude & stulid, Aleksandr's (Y) Awesome advice.
I'm not a fan of the Antec 900/902 really, they're dust magnets and look cheap imo. For that sort of money I'd probably go for the Fractal Design case on TWO.
All of the Gigabyte P55A boards support Sata 6GB/s and USB3.
Although I don't know whether I'd be overly concerned about it at the moment, there's hardly any USB3 devices or Sata 6GB/s hard drives that make use of either technologies yet.
I guess it depends on how often the op upgrades?
True, just trying to keep on looking to get the best and longest lasting pc for the money that's all ;)
